Det är samma bok i olika utföranden och upplagor.
Kolla utgivningsdatum och antal sidor mm. Du kan också leta upp dem på Amazon.com mha isbn. Då får du en mer detaljerad beskrivning av de olika varianterna.
Den nyaste verkar vara:
http://www.adlibris.com/se/product.aspx?isbn=0007320817The bestselling compact guide on how to survive in the wild, in any climate, on land or at sea. This updated edition contains all the latest techniques on survival training and timeless advice from the foremost expert in survival, Lofty Wiseman. All of it is rooted in the training techniques of the Special Air Service, the world's most famous elite fighting force, in which Lofty served for 26 years. Using clear line drawings and colour illustrations, and new case studies and survival scenarios, Lofty describes survival techniques for if you find yourself at sea, in the mountains, at the polar icecaps, or in the desert, complete with what to do in a whole range of medical and meteorological emergencies. Whether you are a camper, a hiker, a sailor or simply engaged in general outdoor pursuits, this book could actually save your life.
Den inbundna är en "lyx-variant":
http://www.adlibris.com/se/product.aspx?isbn=0007312857Luxury edition of the bestselling survival guide This is the original and best survival handbook, now in an exclusive package. Lofty's extensive survival experience and tried and tested techniques are the choice of both survival expert and novice, and the text is specially crafted to prepare you for any and every situation, wherever you are in the world. Lofty imparts his much sought-after knowledge in a new illustrated top-of-the-range gift format, wonderfully packaged as a hardback covered with camouflage cloth, filled with informative and attractive photography. All the advice is firmly rooted in the training techniques of the world's most elite fighting force, the SAS. Whether you are on land, at sea, trekking in mountainous, desert or arctic regions, or in the midst of an unforeseen disaster, Lofty will teach you how to survive. NEW CONTENTS INCLUDE: Step-by-step photography showing you such fundamental survival skills as shelter building, lighting a fire, signalling for rescue, basic first aid, setting up and furnishing a camp, setting up traps. Also includes photography of plants, animals and trees you might be likely to encounter in various climates, to enable easy recognition when you're foraging for food. Case studies form an important part of the text, giving the reader real-life stories to learn from, and test their knowledge against.
Den tredje är en gammal upplaga.
